Re: Hydraulic Piston Question
Posted by Mark on February 13, 2004 at 08:28:50 from (199.46.199.233):
In Reply to: Hydraulic Piston Question posted by scotty on February 12, 2004 at 11:26:22:
scotty, I bought an antique combine one time that must have had 20 hydraulic cylinders and seems like there were 4 or 5 different ways to get at them. I had never done hydraulics before but by the time I had them rebuilt I was pretty good. Repair is not that hard and if you have a reasonable mechanical aptitude you should do fine. If your local IH house can't get seals for you, you should be able to go to a hydraulics parts jobber and get them just by presenting yours to them. Agreeing with info in other posts, there are 2 sealing mechanisms: 1 seals the innards from the outtards, and 2 seals the piston that does the work. With a nut on the end, you should be able to back it off and unscrew it. once you pull the nut out there should be a (outter seal) on the bottom of it. With the nut off, you should be able to plush the movable shaft (containing the piston) toward the open end of the cylinder and the piston will come right out. There should be a screw or another nut holding the packing of the piston and it should be right there in your face. Depending on the type unit (mfgr's choice) something unscrews so that the piston and shaft can be removed from a cylinder. Be sure to pay particular attention to the "packing" as there is sealing packing and then there is pressure back -up packing and you need to insure that the pressure back-up is on the right side of the seal or the first time you power her up you'll blow your seal. Common sense goes a long way on this job and you can do the job for around $35. Might as well do the other side while you're at it. If this side needed it, won't be long before the other will too. Good Luck, Mark PS. On really large cylinders (like on a 100 hp sized front end loader lift cylinders) I had to use a come-a-long to push the piston/shaft back in....and be sure to soak the packing in hydraulic fluid prior to installation. Want things as slippery as you can get them....and don't forget to "vent" the other end of the cylinder when trying to push a piston back in....it's a bear if you don't.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
