Re: What Is It?
Posted by Dave_Id on February 14, 2004 at 10:15:54 from (24.18.119.228):
In Reply to: What Is It? posted by Del on February 13, 2004 at 16:22:40:
Look for the casting number behind the oil filter, and post it. Can't tell from the part #. A 113 cu in. number is 251069R1. They have a 3 inch bore from factory..An F-12 has a 3in bore from factory also.
Post A Followup
: Re: Re: What Is It?
