Re: Farmall H Trans Input and belly pump drive sea
Posted by Rod on February 14, 2004 at 19:09:47 from (64.12.97.12):
In Reply to: Farmall H Trans Input and belly pump drive seals posted by Mark Russette on February 14, 2004 at 10:24:21:
Mark,
As already mentioned, replacing the counter-shaft seal at the transmission side is no problem. However, if the bar method does not work I found a heavy pipe wrench does the trick easily.
Post A Followup
: Re: Re: Farmall H Trans Input and belly pump drive sea
