Re: cold weather diesel
Posted by riverrat on February 15, 2004 at 18:49:14 from (170.215.192.66):
In Reply to: cold weather diesel posted by Matt on February 15, 2004 at 17:38:54:
Time to get out the salemander heater and the tarp! Wrap your tractor in the tarp, point the tube inside, careful not to set the tarp on fire or melt it and wait about an hour. Then drain the tank, put in your blend and start it. The fuel lines should be warm enough to pump through and get the blended fuel into the pump, then you're home free. Done it. Works. Good luck!
Post A Followup
: Re: Re: cold weather diesel
