Farmall Tractors Discussion Board
Re: Re: Re: Hey ltf in nc !
Posted by ltf in nc on October 15, 1999 at 17:44:53 from (206.228.213.168):
In Reply to: Re: Re: Hey ltf in nc ! posted by Ludwig on October 15, 1999 at 12:05:54:
Now I have got both of you. I say this good naturedly and in a joking manner so do not be offended. You do not polarize the regulator. Your instruction do tell you to jumper AT the regulator. With that I fully agree. However you are not polarizing the regulator. You are polarizing the generator that is connected to the wires that your instructions told you to jumper. This will match the polarity of the generator to the battery that is installed in the tractor. Ludwig, I have gotten a tingle from a wet situation as you described but nothing more. Are you sure you did not hit the nerve in your elbow as it also gives the same undesireable sensation? If you will support yourself on your heels when exposed to a shock the jolt is much less severe. You men have a good day!
Post a Followup
: Re: Re: Re: Re: Hey ltf in nc !
