Re: Coil Question
Posted by Mark on February 16, 2004 at 06:18:42 from (199.46.199.232):
In Reply to: Coil Question posted by Peabody on February 15, 2004 at 18:00:33:
Peabody, I may be steering you wrong here but I have been interested in things like "what parts get changed when you go from a 6 to 12v conversion"? The name of the game is "energy to jump the sparkplug gap". The points are a switch that lets current from the battery flow through the coil. While doing that it is filling the coil with "energy". The name of the game is to just put enough current into the coil [in the time allowed by what's called "dwell"....hence how long you stay (dwell)] to satisfy the energy requiement of the plug selected.....what is it's temp range and how wide is the gap. If you run the current too high (put in more energy than the plug needs) you reduce the life of the points as when the points open there is a spark (caused by the coil) and the energy in that spark determines the damage to the points for that firing. (That's why on transistor ignitions, points last forever. A transistor is switched by the points and it electronically does the switching....course they have problems with not enough current to keep the points "clean". I have been told that 12 volt coils are just 6v coils with an internal ballast (current limiting) resistor. Some have a sign on the side stating that fact. When you Ohm out the primary of your "12v" coil, you should read at least 2 Ohms. My experience with primary (distributor) circuits is that there is somewhere between 2 to 6 ohms of resistance in the circuit going from the battery thru the coil primary, thru the points and to gnd.
If you go to the auto parts store and get an adjustable ballast resistor, you could set the value yourself. Put the resistor in series with the coil lead mentioned just above. Set the tap on the maximum resistance (6 ohms?). Attempt to start the engine. If you have adequate spark stop there and leave it alone. If not reduce the resistance to 4 ohms then 2 ohms if necessary. If nothing else is wrong you will get the desired result. Need more, ask.
Mark
Home
| Forums
Today's Featured Article -
A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
