smta worm gear lube
Posted by paul on February 16, 2004 at 17:23:42 from (216.114.4.168):
In checking all lube points on my smta I took the cover off the worm gear housing.Previous owner had the housing packed with grease,service manual calls for 80 wt gear oil I think both of these choices are to thick should I remove the grease and fill with hy-trans have some left over from ta job.Paul.
Post A Followup
: Re: smta worm gear lube
