Re: cold weather diesel
Posted by BIG JOHN on February 16, 2004 at 18:56:00 from (205.188.209.82):
In Reply to: cold weather diesel posted by Matt on February 15, 2004 at 17:38:54:
I don't know where some of these guys are coming from with those -30 degree temps before diesel will jell. Here in Kansas if you don't use winter conditioned diesel you will jell up at around 20 degrees.
If you are jelled up you will need to get your complete tractor/truck or what ever it is into a heated space and get it warmed up to about 40 degrees. Pull and replace your filters. Put a heat lamp on the engine compartment to warm up the injectors. Add some type of conditioner to the fuel in the unit and reprime the whole system.
Post A Followup
: Re: Re: cold weather diesel
