Re: Re: Re: Farmall H Starter
Posted by Bob M on February 17, 2004 at 12:55:07 from (165.170.128.65):
In Reply to: Re: Re: Farmall H Starter posted by Pat Connors on February 17, 2004 at 12:27:20:
Pat - The starter is polarity insensitive - you can bench test it either way (positive or negative ground) and it won't care.
Note! If you bench test the starter make sure you clamp it securely in a vise or something. If it's just sitting loose on the bench and it tests good, it'll twist violently the instant you make the connection with possibly dire consequences! Also expect a fairly substantial spark when you make the final electrical connection!
Recommend however before you do a bench test, remove the dust band and peek inside at the brushes/commutator. You may find one or more brushes has worn out or broken and the commutator is burned/dirty. Cleaning the commutator and replacing the brushes may solve your problem.
Post A Followup
: Re: Re: Re: Re: Farmall H Starter
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
