Re: Bob M
Posted by Bob M on February 17, 2004 at 16:48:42 from (66.67.9.170):
In Reply to: Bob M posted by Jimmy on February 17, 2004 at 16:33:38:
Jimmy - Here's a couple things to look for:
1 - The alternator may not be spinning fast enough at startup to "turn it on". Try running the engine up to full speed. If the light goes out and the ammeter now indicates a charge, the problem is solved. (Once the alternator is turned on it will continue to charge at lower RPM). If this turns out to be the problem consider installing a smaller pulley on the alternator to spin it faster.
2 - The warning lamp bulb may be too small. The bulb must draw at least 0.2 amps in order to turn on the alternator. (A #1850 or #168 side marker/instrument panel bulb is the right size.) You can verify by momentarily shorting the #1 and #2 alternator terminals together with the engine running. If the alternator charges (and the lamp stays dark after you remove the jumper) it means the bulb is too small.
Post back what you find!
Post A Followup
: Re: Re: Bob M
