Re: Re: Re: Re: Re: Brake band replacement on 47 A
Posted by Rick L. on February 17, 2004 at 19:13:51 from (206.222.201.197):
In Reply to: Re: Re: Re: Re: Brake band replacement on 47 A posted by scruffy on February 17, 2004 at 18:06:32:
Yeah! And maybe the nitrous injectors will help me get it started moving again! Actually, I use the 460 for bale moving, so I'm set for that. Thanks,
Rick
Post A Followup
: Re: Re: Re: Re: Re: Re: Brake band replacement on 47 A
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
