Re: M hard start / choke ??
Posted by Dave in CT on February 18, 2004 at 20:41:54 from (204.60.45.154):
In Reply to: M hard start / choke ?? posted by Brad on February 18, 2004 at 18:05:54:
Disconnect the fuel line to the carb, clean the screen in the carb where the fuel line connects. If you don't get a good stream of gas coming out of the fuel line at this point, check the screen at the sediment bowl. If you've gotten a lot of rust there, or even if you haven't, swipe a magnet around the inside of your fuel tank near the sediment bowl inlet, to pick up any loose rust flakes. I had a similar problem with my '47 H. After a few sweeps, I left the magnet in the tank, near the inlet, where it continues to catch the occasional flake.
Post A Followup
: Re: Re: M hard start / choke ??
