Re: Re: 504 Grinds when shifting
Posted by Stan(VA). on February 19, 2004 at 04:44:49 from (208.59.156.61):
In Reply to: Re: 504 Grinds when shifting posted by Hugh MacKay on February 18, 2004 at 14:54:35:
And if you're not trying to shift on the fly, but it's grinding anyway, you should start with the TA adjustment proceedure that's in the manual. I would try that before tearing it apart to replace something. I had a 504 that would try to keep crawling with the clutch pedal down, it definately would grind the gears untill I went through the TA adjustment process. That alone is worth the price of the manual, a picture is worth a thousand words.
Stan(VA).
Post A Followup
: Re: Re: Re: 504 Grinds when shifting
