Farmall Tractors Discussion Board |
Re: Super M turning green
Posted by F14 on October 16, 1999 at 04:40:14 from (204.176.212.3):
In Reply to: Super M turning green posted by Joe Berendzen on October 15, 1999 at 20:34:52:
What you need is a good Anti-JD-Virus protection program. Add a little to the oil, fuel and water, and every time you "boot" the M, the A-JD-V will inspect all the "startup" routines and remove any JD viruses (virii?) Be sure to park the M on an impermeable surface, preferably with a DEP-approved drainage and collection system, so all that green slime that will run out the breather tube will be safely contained. That should keep you going until you can "upgrade" to the full IH package again.
Post a Followup
