blows-out oil filter cap gasket
Posted by Paul on February 19, 2004 at 17:03:28 from (64.146.108.174):
after changing the oil and oil filter in my 1948 Farmall Cub and replacing the filter cover held in place by the filter through bolt the first several attempts at running the engine result in pressurized oil blowing out the gasket under the filter cover. Three or four of these attempts yield the same results and then for no reason that I can see it will then run normally with no blown filter cover gasket untill the next oil filter change. What is going on?
Post A Followup
: Re: blows-out oil filter cap gasket
