Re: Farmall 560( HELP)
Posted by E J on February 19, 2004 at 18:28:53 from (67.31.155.50):
In Reply to: Farmall 560( HELP) posted by Pat on February 19, 2004 at 17:04:02:
yes I have a 403d in my 560 change the front motor plate from tractor too combine engine use tractor flywheel and rear engine plate.You must use the castiron filter base off the tractor on to the combine engine if it has the aluminum one to clear the steering shaft you need to plug one hole and drill another for oil bypass.The combine engine will run more rpm than the tractor engine.
Post A Followup
: Re: Re: Farmall 560( HELP)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
