Re: Wire order on distributer cap
Posted by jed on February 20, 2004 at 05:30:40 from (66.212.143.210):
In Reply to: Wire order on distributer cap posted by Tree K on February 19, 2004 at 19:50:58:
It doesn't matter if you have a distributor or a mag., the firing order should be 1342, starting from the number 1 position on the cap. All of the Farmall gasoline engines run clockwise and the letter diesels run counterclockwise. To set the firing order remove the #1 plug and raise the cylinder to the top on the compression stroke. This you will know because it blows out air on compression. You can hear it and feel it. Double check it with a bent wire through the plug hole and you can feel the piston in the up position. Now replace the wires as described. You should be good to go. If you still have problems look elsewhere.
Post A Followup
: Re: Re: Wire order on distributer cap
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
