Re: Farmall H starting problems
Posted by Bill Smith on February 20, 2004 at 09:50:24 from (63.147.130.118):
In Reply to: Farmall H starting problems posted by Garrison in Maryland on February 20, 2004 at 06:51:39:
If you are choking while trying to start, it could be that you are overchoking (raw gas will run out of carb). Otherwise gas leak is most likely related to a float/needle valve problem in carb (very common, but will most likely do it a few seconds after turning gas on, even without turning tractor over). If this isn't starting problem, you might want to adjust carb according to manuel, do a spark test, ext.
Post A Followup
: Re: Re: Farmall H starting problems
