SMTA hydraulics again
Posted by Dan Wa on February 20, 2004 at 21:04:28 from (12.160.171.186):
Figured out why I couldn't get it to work right. Have system plumbed now so all valves, christmas tree, regular hydraulic and liftall valve are in series. Had to move lift all handle to neutral position to get others to work right. Now I am concerned that I have no relief valve in at least part of the system and if that will damage pump. Plumbed as follows, pressure line from live pump to inlet of christmas tree valve, outlet of christmas tree to inlet of other hydraulic valve, outlet of that valve to inlet of lift all valve reservoir, return line from reservoir to pump. Other valves won't work when lift all handle locked back. Do I have a problem? Thanks in advance
Post A Followup
: Re: SMTA hydraulics again
