Farmall Tractors Discussion Board
Re: Re: too many bearings!
Posted by RickB. on October 16, 1999 at 07:19:16 from (205.231.25.162):
In Reply to: Re: too many bearings! posted by The Red on October 15, 1999 at 07:38:02:
It will probably take a small neuclear device to remove that axle shaft from the lower bolster, unless it is already loose, in which case the new one will be loose too. Search salvage yards for a complete lower bolster, taking care that it will use the same hubs and bearings as your present one.
Post a Followup
: Re: Re: Re: too many bearings!
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
