Re: Re: SA-- Bad starter bendix??
Posted by rebuilder on February 21, 2004 at 14:12:17 from (66.228.102.248):
In Reply to: Re: SA-- Bad starter bendix?? posted by Hugh MacKay on February 21, 2004 at 12:36:47:
Hugh;
The drive you are describing is called a "barrel" type drive. I assume due to the clutch caseing. I am somewhat nuetral as to the benefits of this particular drive. Many of the starters I rebuild have this style drive and have very little use(low hours)on a previous rebuild but show a lot of wear and poor engagement. I myself have not had extensive first hand use as my tractors are set up with the old sping style. However,I use the spring style in 100% of the starters I rebuild.
Post A Followup
: Re: Re: Re: SA-- Bad starter bendix??
