Re: IH custom cab
Posted by JD Humm on February 22, 2004 at 08:29:11 from (206.214.163.162):
In Reply to: IH custom cab posted by max adams on February 21, 2004 at 17:56:24:
We had the Excel version of this cab on a 1256. Did the cab come off of a larger 56 tractor or did it come off a 756? If it came from a larger one you will have to remake the sheetmetal that goes around the fuel tank. Wilson is right, you need the platform parts, too, unless you are good at fabrication. I forget exactly how it all went together but it should be a pretty straigt forward installation. You should have axle brackets that go around the axle housing, that is the main rear attachement to the tractor, the front of the platform bolts to the present step bracket area and the cab rests on isomount rubber bushings at four points. Basically, you install the platform, axle brackets and front brackets first, then the cab sits down on the four rubber bushings, foam is used to fill the gap between the two major parts. After that you install the front sheemetal around the fuel tank that I mentioned above and then install the rear sheetmetal around the rear of the tractor that fills the gap between the tractor and cab. We isolated as many contact points as possible between the tractor and cab, wrapped rubber around the axle housings where those brackets clamped on and the cab was suprisingly quiet, almost as quiet as my 76 model 1566 was. A good heavy rubber floor mat helps too. Don't know if you can still get a factory mat or will have to make something. My email is not hidden and I do not look at this site a lot, so drop me a line if you have more questions.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
