Re: IH custom cab
Posted by Hugh MacKay on February 22, 2004 at 14:16:33 from (64.228.12.139):
In Reply to: IH custom cab posted by max adams on February 21, 2004 at 17:56:24:
Max: I installed one of these Excell cabs from a 1066 and put it on my 656. I had to make a lot of modifications as the chassis is very much different, on a 656. Follow JD's advice, he is good on this and ten years younger than I am so he's not rusty. Probably not as grumpy as I am either. I was always in a hurry back then so never did get mine closed in tight at the back. It was still a lot better drilling or planting corn on 40F evenings. Your change should be a picnic, as JD said get the cab mounted then close it in from there.
Post A Followup
: Re: Re: IH custom cab
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
