Re: sickle mowers
Posted by Dave H (MI) on April 01, 2009 at 09:49:12 from (64.12.116.73):
In Reply to: sickle mowers posted by howling wind wayne on April 01, 2009 at 07:46:56:
Done a lot of research on this one myself. Put a picture up if you can. IF not, then narrow it down a little. The type of drive system on the mower will cut it down some. Pitman drive or belt drive? IH made a whole series of mowers starting in the late 50's called "balanced head mowers" which had a belt drive system. You said bolt on....was that in the rear or is it mid-mount? Does it have a trailing wheel? Picture and/or more details would help.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
