Re: Converting Mag on an H to use a 6 volt igniti
Posted by Nebraska Cowman on February 22, 2004 at 18:31:00 from (65.172.142.111):
In Reply to: Converting Mag on an H to use a 6 volt ignition c posted by Jerry on February 22, 2004 at 18:03:52:
I think all you need to do is run the wire from your new coil in to the existing condenser and clip the wire from the mag coil. maybe someone else will give more detailed instuction.
Post A Followup
: Re: Re: Converting Mag on an H to use a 6 volt igniti
