Re: Next Project --- SMTA with STUCK ENGINE!!!!
Posted by Dan Kelley on February 23, 2004 at 07:38:42 from (140.32.120.18):
In Reply to: Next Project --- SMTA with STUCK ENGINE!!!!!!! posted by BIG JOHN on February 22, 2004 at 18:58:00:
I worry about the compressed air method, because once the air breaks the rings loose, you could shoot the pistons to the bottom of the bore with considerable speed. You can easily break things like that. Here's something I've been thinking of doing on my Case VAIW with a stuck motor. Rig an adapter for your grease gun to the sparkplug holes. Remove the rocker shaft and be sure the valves on the selected cylinder are closed. Remove all the spark plugs. Start pumping grease into one of the cylinders, then move to the next and then the next. You may even want to see about working a bunch of grease into the cylinders before hooking up the adapter. You want to get as much air out of the cylinders as possible before hooking up the adapter. Go slowly. Work a little on one cylinder, and then a little on the next. Remember that you will have a bunch of hydraulic advantage with a grease gun. If you do not go very slowly, you can bend things. Regardless, this method has the advantage of more control. The hydraulic pump idea will not be as nearly controllable as the grease-gun idea. Both of those methods have the advantage of the fact that fluids are not compressible. So, once you let off, everything should stop. With the air method, once you let off, things will keep moving until the air has decompressed.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
