Re: ROCKFORD CLUTCH IN H
Posted by Dr.EVIL on February 23, 2004 at 11:58:49 from (12.4.181.2):
In Reply to: ROCKFORD CLUTCH IN H posted by LOU on February 23, 2004 at 05:58:12:
Rockford Clutch was a supplier to IHC up until the very end in 1985. It was decided when They started supplying pressure plates & clutch discs to FARMALL to make the destinction on the serial number plate. Yes, Rockford made Very good clutches, but they were just a "LONG STYLE" clutch with three narrow release levers. Other clutches have been known as the Borg & Beck, and the Diaphram style pressure plates. Rockford Clutch was the ONLY supplier to IHC in the 70's & 80's when Rockford was supplying the Cera-Metallic 4 and 6 puck style clutches to IHC.
Post A Followup
: Re: Re: ROCKFORD CLUTCH IN H
