Re: Re: 300 utility 5th gear speed
Posted by Dr.EVIL on February 23, 2004 at 12:04:16 from (12.4.181.2):
In Reply to: Re: 300 utility 5th gear speed posted by Randy in NE on February 23, 2004 at 04:18:00:
The rowcrop FARMALL ran 1750 RPM and had 38" rear rubber, The International utility tractor ran 2000 RPM and only had 26" or 28" rear rubber. I think the final drive reduction ratio also changed between the rowcrop & utility, the bullgear & pinion tooth could could be different.
Post A Followup
: Re: Re: Re: 300 utility 5th gear speed
