Re: Repair parts for my Farmall 100
Posted by Farmer Bob on February 23, 2004 at 20:37:25 from (64.113.13.86):
In Reply to: Repair parts for my Farmall 100 posted by Bruce Haebe on February 23, 2004 at 20:22:28:
Probably the best place cost wise for the gaskets is your local NAPA store. They can cross reference the gasket and will order it in for your pickup if they don't have it in stock. Some folks have mentioned that original gaskets from Case/NH seem to be of better quality than the off brands. I've had good luck with both.
As far as the oil pump goes, It's doubtful you will find a "New" one in stock anywhere. You may be able to rebuild your existing pump or find a better one off of a salvage tractor with C123 engine.
Post A Followup
: Re: Re: Repair parts for my Farmall 100
