Re: Do not do !!!!!
Posted by Maniak on April 01, 2009 at 10:01:05 from (65.166.205.254):
In Reply to: 6v, 12v negative or positive ground? posted by Brownie 450 on April 01, 2009 at 04:00:22:
Brownie 450 said: (quoted from post at 04:00:22 04/01/09) Jim---shouldn't the start switch be originating from the hot terminal on the battery instead of going to ground?
That still confuses me too.. I just can't get my head around a negative triggered 6v starter solenoid. Assuming thats what it is (6v negative triggered relay) then as far as I can tell its wired right..
It "was" a running tractor until is was parked a few years and then someone tried to start it, couldn't and then I got it. From what I gather, not much was done to try to get it to start and from looking at the condition of the wires/dirt etc that solenoid has been on it for years..
~Mark
