Re: Re: Re: B-250 sleeve won't come out- help!!!
Posted by jdemaris on February 24, 2004 at 18:41:55 from (209.23.30.5):
In Reply to: Re: Re: B-250 sleeve won't come out- help!!! posted by Paul on February 24, 2004 at 09:38:31:
I don't understand what you mean by not being able to use a sleeve puller. It there's any part of the sleeve there, a puller will work and it doesn't matter if the top is broken off it. A sleeve puller pulls from the bottom of the sleeve, not from the top. An adapter that has a slightly smaller outside diamater than the sleeve o.d. is installed at the bottom of said sleeve. A long threaded rod is attached, and . . . pulls the sleeve from on top of the block.
You could make one if desired. Get a piece of steel that just barely grabs the walls of the sleeve - but it can't be any larger diameter than the sleeve because it has to travel through the block. Drill a hole in it, and then run a piece of threaded rod from it (at the bottom of the sleeve) out through the top. You also have to make an adapter that will fit on top that serves as a bushing that the entire sleeve can pass through. This has to have an i.d. large enough for the entire sleeve o.d. to pass through. On top of the bushing, you need a crossbar of some sort that the threaded rod can be attachend to. Then you put a nut on it, and pull the sleeve out. The sleeve will only come out until it hits the crossbar, so if you made the bushing 2" tall, the sleeve will move 2", etc. It's not matter, once you get it to move an 1/8", the rest will be easy.
As far as your idea of welding a bar on it and then hooking a loader to it - how is that any different than what I described earlier, i.e. putting a hydraulic jack underneath and jacking on the sleeve bottom?
I've rebuilt hundreds of diesels, and never had one yet that I couldn't get a sleeve out.
Post A Followup
: Re: Re: Re: Re: B-250 sleeve won't come out- help!!!
