Posted by T.S. Eliot on April 01, 2009 at 10:22:14 from (129.72.189.121):
If your time and your weather (I'm upwind from you in Wyoming) permit, could you measure the spacing/clearance between the inside of your front rim and the HD Schwartz spindle on your "M"?
(You are owed an explanation: I'm making my M into a beefy loader tractor, and I've switched out the M castings (one was cracked anyway) for 560 castings and 18.4 x 38's on double bevel rims. But, as I always anticipated, the 8" increase in diameter from 13.6 to 18.4 necessitates a raise in front tire diameter to level out the tractor. I'm picking up my new HD Schwartz front end in Iowa next month, but I'd like to order GENSCO flotation/aircraft tires so they are here before the Schwartz is. GENSCO sells a 36 inch (38 nominal) tire 12.5 inches wide, with a 1 inch positive backspace - doing the math, that would mean I would need at least 7.25 inches of clearance from where the rim mounts on the hub to the spindle.)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
