Re: Hey Bob Melville?
Posted by Doug in OR on February 26, 2004 at 08:38:52 from (159.121.94.198):
In Reply to: Hey Bob Melville? posted by DHuth2 on February 25, 2004 at 20:22:54:
Bob can probably add to this, or correct a little of what I say. First of all, what year is this truck? The Delco alternators that were built after the 10SI was discontinued use internal sensing. Simply put, they run a low-value resistor from the BAT terminal to the sensing circuit. You can still use external sensing if you wish. Even the 10SI can be modified to use internal sensing. This is sensing only - excitation is another story. You can find "single wire" alternators that also use internal excitation. These are usually modified 10SI alternators. I usually preach to use 3-wire configurations for two reasons: 1) They are more readily available and less expensive. 2) You do not need as much RPM the start the alternator charging. This can be a significant issue when you are driving an alternator with a low RPM engine - as found on a tractor. I might mention that while 14.6 volts is satisfactory, it is a bit high. Something around 14.0 volts is more desireable. With a 14.6 charging voltage, you will need to watch the battery a bit more closely. The battery will tend to use more water.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
