Farmall Tractors Discussion Board
Re: The Dummy broke it!
Posted by ltf in nc on October 17, 1999 at 12:18:13 from (206.228.213.127):
In Reply to: The Dummy broke it! posted by MrGadget (aka Dummy) on October 17, 1999 at 10:07:27:
Can you not jack the axle with the broken spindle real high to where you can place a block of wood under the stop mechanism that limits axle pivoting and thus have the good wheel as the single front wheel and limp home? The bush hog will offset some of the front weight and if you wanted you could put some weight on the back of the bush hog and counterweight the front to where the load on the front axle is nearly nothing. Be careful and good luck.
Post a Followup
: Re: Re: The Dummy broke it!
