Re: belly mower AND a 2pt FH on a 140??
Posted by Hugh MacKay on February 26, 2004 at 18:02:57 from (64.228.13.166):
In Reply to: belly mower AND a 2pt FH on a 140?? posted by Pete in PA on February 26, 2004 at 17:17:56:
Pete: You say 2 point fast hitch, are you planning to modify and fabricate a 2 point to fit the 140. The factory fast hitch for a 140 is just 1 point. I'm not saying this can't be done using the 2 point hich from a SC or 200, and with a bit of modification may work better than the 1 point with belly mower. Is your mower powered from the pto shaft or from the belt pulley shaft? My first concern is, will the 2 point hitch frame from a SC or 200 fit between the final drives of a 140? I don't know. Do you have any photos of the tractor as it is currently?
Post A Followup
: Re: Re: belly mower AND a 2pt FH on a 140??
