Re: Farmall Super C running bad HELP
Posted by Dave_Id on February 28, 2004 at 15:49:46 from (24.18.119.228):
In Reply to: Farmall Super C running bad HELP posted by Randy Bishop on February 28, 2004 at 14:19:21:
You could have a bad coil.. also check to make sure you have a good flow on your carb out of the tank.. Maybe the opening in the tank is plugged or the screen is plugged on your glass sludge separator
Post A Followup
: Re: Re: Farmall Super C running bad HELP
