smta polarize
Posted by paul on February 28, 2004 at 17:33:19 from (216.114.4.202):
After ta overhaul I got in a hury and started the tractor without polarizing the generator. This is a 12 volt negative ground system should I disconnect the battery and reconnect before polarizing or just polarize it.Also when I pull out the switch the amp guage shows a slight charge,battery has since run down but if I turn on the lights with the tractor running amp guage shows almost full charge what gives?? Paul.
Post A Followup
: Re: smta polarize
