Re: trying to get bearing off help!!!!
Posted by lee on February 28, 2004 at 20:39:18 from (24.24.92.235):
In Reply to: trying to get bearing off help!!!! posted by Jon on February 28, 2004 at 19:16:54:
Jon, are you sure the problem is in the rear axel bearings? Those bearings don't often fail unless the drive has taken on a lot of condensation or the gear lube has leaked out and it's rusted up. How far have you taken it apart? Your problem could be in the brakes on the diff drive shafts. Do you have a repair manual? The manual has drawings that will show you how the thing is built. Which side of the tractor are you working on? To remove the rear axel bearings you need to remove the rear axel shaft. You can tussel with it on the tractor. It may not be a gravy job. Support the tractor well. You are going to be underneath. Block the wheels. Remove the rear wheel. Remove the bottom pan. Remove the cap on the inside under the tractor. Remove the 4 bolts from the outer bearing retainer. Remove the bolt/washer/spacer on the end of the axel shaft under the tractor. Put wood blocking under the bull gear so it doesn't drop to the floor when you drive the axel shaft out from underneath. Put the bolt back in the axel shaft underneath less the washers and spacers. Drive the axel out of the housing with a large soft faced maul on the bolt from underneath. Wear safety goggles. The bolt is hard. If you have a large brass drift use it with a steel maul. If you are beating on that hard bolt with a large hard faced hammer (not recommended) there is danger for slivers to fly off at high speed. These slivers can fly and penetrate the skin. There are spacers internal. The outer bearing may go with the shaft but may stay in the housing. The inner bearing may go with the shaft for a small distance til the bull gear contacts the housing at which point the shaft must be driven til the bearing is off the shaft.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
