Re: farmall Tractor rear axel problem
Posted by lee on February 29, 2004 at 09:10:24 from (24.24.92.235):
In Reply to: farmall Tractor rear axel problem posted by Jon on February 29, 2004 at 07:08:12:
I've done these. They can be stubborn. Sounds like you have the axel housing off the tractor? If the bull gear is contacting the housing it has moved some! You need to persuade it harder! Do you have it blocked up solid so you can get a good bump on it with your persuader. How big is your persuader? I used a 6 lb maul and drift. It is s stuck now on the inner bearing for most part or on dirt and grease in the bore of the outer I gather. The shaft must be bumped thru the innner race of the inner bearing. The bull gear is splined to the axel shaft and just slides on so axel should pass thru. MAKE SURE YOUR BOLT IS NOT CONTACTING THE INNER RACE OF THE INNNER BEARING. You may need a drift on the shaft slightly under size of inner race. If you have a torch you can heat the nose of the casting some near the hub and/or the inner bearing if possible if you plan to replace. If you cannot get it you will need to take it and have it pressed out. Replacement of bearings may be necessary.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
