Re: 1066 clutch or ta,
Posted by Rich on February 29, 2004 at 09:24:24 from (69.66.97.4):
In Reply to: 1066 clutch or ta, posted by mike on February 29, 2004 at 01:03:24:
Can be weak MCV pump. At the time that it quits moveing,do you still have power steering? If not,probably the pump,if you do,probably TA.
Post A Followup
: Re: Re: 1066 clutch or ta,
