Re: removing the belly pump on a super M
Posted by NDS on March 01, 2004 at 09:03:28 from (64.12.97.12):
In Reply to: removing the belly pump on a super M posted by John (AZ) on March 01, 2004 at 07:25:00:
The main difference in H and M is drive coupling the M is actually easier IMHO. M is driven by a "driving dog" that fits into 2 slots. Just turn it to right position and let pump down and it will fall out. When you get in to where you can see it procedue will be obvious.
Post A Followup
: Re: Re: removing the belly pump on a super M
