Re: Farmall 100 spindle and axle ?
Posted by scotty on March 01, 2004 at 12:59:45 from (199.231.49.128):
In Reply to: Farmall 100 spindle and axle ? posted by mdshilli on March 01, 2004 at 11:31:49:
mdshilli,
The fit between the spindle shaft and the tube crossmember should be a nice slide fit. At the very least you should have checked what kind of fit you had before assembly. It is possible that during assembly you could have had a slight alignment problem and burred up the bearing on the opposite bushing on the crosstube. There should not be any serious hammering during that assembly. A little grease inthe bushings and on the shaft should be all thatis required.
scotty
Post A Followup
: Re: Re: Farmall 100 spindle and axle ?
