Re: Farmall M Head: To shave or not to shave?
Posted by Randy-MN on March 01, 2004 at 14:11:33 from (206.9.216.81):
In Reply to: Farmall M Head: To shave or not to shave? posted by Luke on March 01, 2004 at 10:23:59:
Luke, you can resurface the head as long as you don't take off so much that you lose your ability to adjust your valves. Remove only what needs removing to clean it up. Remember...shortening the head lengthens the pushrods...
Post A Followup
: Re: Re: Farmall M Head: To shave or not to shave?
