Super A block update
Posted by VAJerry on March 02, 2004 at 16:45:15 from (207.78.118.94):
Bought a die grinder today and start to grind the weld off. Started to fly off in chunks. Got it all off, now this is what I have: a crack that runs from the front under the second manifold bolt back to just in front of the bolt holes where the air cleaner mounts. About 12 to 15 inches. The last 2 inches or so are about 1/2 to 3/4 inch wide. Looks like when they welded it they burnt though the block several times before they were able to build up the bead. Now I don't know if JB weld will cover this satifactory or not. Another thought would be to get some 3/16 steel and weld it in place, covering the whole mess. Asking for input.
Post A Followup
: Re: Super A block update
