Re: how to tell if a head is cracked
Posted by ChadS on March 03, 2004 at 09:31:57 from (66.228.96.176):
In Reply to: how to tell if a head is cracked posted by jeff on March 03, 2004 at 08:27:07:
I had a simular problem with my H pulling tractor. I had the head magnafluxed, and pressure tested, and put it back on and it still leaked. In the same place you mentioned. I removed the stud, and put thread sealer on the block end of the stud, and put a flat washer on the head and shot silicone in the head stud hole and tightend it up. It sealed it up, and has not leaked since. I have went to the extent of putting a pressure tester on the radiator cap to check for leakage internally, and had none. More than likely, it is comming out of the block side of the stud through the threads and just filling up with antifreeze when the pressure builds in the system. Hope this helps, ChadS
Post A Followup
: Re: Re: how to tell if a head is cracked
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
