Re: When does a head need rebuilding on an F-20 ?
Posted by Bill Smith on March 03, 2004 at 12:02:48 from (63.147.130.92):
In Reply to: When does a head need rebuilding on an F-20 ? posted by Pete L on March 03, 2004 at 10:30:51:
Burnt valves ussually will make a popping noise when engine is running. The sound will either travel out the exhaust or back through the intake. Bad seats or valves can incorporate a mis. F-20's are natorious for sticking valves also. You want to be darn sure that you don't have a valve or valves that are sticking open all the time or even once in a while. Remember that the stuff under the valve cover needs to be oiled every so many running hours. As Dave said, you might want to do a compression test. If you come up with low readings, squirt some oil in on top of the pistons and do it again. If you still have low readings, you have bad valves or seats. If the readings were low and oil brings the compression readings up to normal, you are losing compression at the piston rings (either bad rings or to much sleeve wear). If you pull the head to do a head job, be sure the valves, seats, guides, and everything is checked out in the head. Also check the head for flatness (most likely will be alright) and you will most likely want to use all new gaskets when you put it back together.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
