Re: how to tell if a head is cracked
Posted by Roger WI on March 03, 2004 at 20:05:42 from (69.58.129.155):
In Reply to: how to tell if a head is cracked posted by jeff on March 03, 2004 at 08:27:07:
Jeff, I just put the studs back into the block on the H I am rebuilding the engine on. There are several studs on the left side of the block that go through into the water jacket and some on the right that go through into the valve lifter cavity. I coated all these studs with a sealant before screwing them into the block to keep them from leaking like you must have. I know one was the stud that is in the throttle bracket. Roger
Post A Followup
: Re: Re: how to tell if a head is cracked
