Farmall Tractors Discussion Board
Re: Farmall Crawlers
Posted by Harold H on October 18, 1999 at 12:55:06 from (207.244.58.230):
In Reply to: Farmall Crawlers posted by Shawn on October 18, 1999 at 11:46:46:
Shawn,
International Harvester crawlers were never Farmall. They originally were McCormick Deering TracTracTors then McCormick TracTracTors then International TracTracTors then just plane International. The T-20 had the same size engine as the Farmall F-20, the T-30 was the same size engine as the Farmall F-30 and the T-40 and TD-40 were the same size engine as the McCormick Deering W-40 and WD-40 tractors. They were replaced by (equivilent tractor engine size)the T-6 (M), TD-6 (MD), T-9 (W-9), TD-9 (WD-9), TD-14, and TD-18 in 1939.
Harold H
Post a Followup
: Re: Re: Farmall Crawlers
