Re: Re: H Clutch pilot bearing removal
Posted by GG on March 05, 2004 at 10:02:45 from (68.62.175.199):
In Reply to: Re: H Clutch pilot bearing removal posted by Dave_Id on March 05, 2004 at 08:53:45:
The simplest way to remove this bearing is to fill the cavity with THICK grease, then use a suitable rod that is very close "slip or slightly snug" to the bearing i.d. Use this rod to compress the grease and it will drive the bearing out. It's messy sometimes, but it works, I have done this many times. The rod should be the same diameter as the machined surface just forward of the clutch splines on the input shaft of the transmission. It works because hydraulic pressure presses the bearing out. Hope it works for you!
Post A Followup
: Re: Re: Re: H Clutch pilot bearing removal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
