Re: Increasing Generator to 8 volts
Posted by Bob M on March 05, 2004 at 10:41:06 from (165.170.128.65):
In Reply to: Increasing Generator to 8 volts posted by Ted on March 04, 2004 at 14:42:00:
Ted - The answer here is “it depends”! If the charging system is manually-regulated (has a simple cutout relay and a 4-position light switch) simply leave the light switch on the “H” (high charge) position. The existing setup will charge your 8 volt battery with no particular difficulty. However if your tractor is a later model with a voltage regulator (or had a cutout replaced with a regulator), the regulator's set point will need to be tweaked up to about 9.6 volts for it to supply a reasonable amount of charge current - exactly as Buzzman and Mark suggest. BUT....as long as your starter and battery cables are in good condition you shouldn’t need an 8 volt battery in the first place. A healthy 6 volt battery will easily spin your higher compression A engine. Often a “slow crank” problem is traced to the battery cables and connections. If the cables are original, good chance they have high resistance from internal (hidden) corrosion. And if the cables have been replaced, many times the replacement cables are several wire gages too small. If either of these situations apply, replacing existing cables with new ones of the correct gage can work wonders. Bottom line is it’s generally more prudent to spend $$ getting the cranking system back into good order than to spend the same $$ on an 8 volt battery “band aid fix”.
Home
| Forums
Today's Featured Article -
Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
